Scotttkd2
- Jun 1, 2021
- King Aire 4561
- Spartan K3
- Cummins ISX 650
- Ford Cmax
- Yes
Thought I would make an update, I finally got out of the "starlink cable through the window" mode. I looked in the master bedroom cabinets and found a cat6 cable labeled satelite, toned it and found it in the basement. I cut it, put a cat6 jack on one side and cat6 plug on the other, so I did not ruin future use of the cable as it was intended to be used. For my purposes though, I plugged the cat6 plug into the starlink adapter and router now moved to the basement, the other end into the wan port of my pepwave max duo mounted in the area where the bedroom tv used to be. Accomplished what I wanted which was a cat6 cable up in the bedroom in the TV compartment but without having to run new cables in to and through the full wall slide mechanism. Using my existing ubiquiti router fed from the pepwave lan port for wife to plug ethernet into and for wifi in the coach, and all working well. Happy to not have the cable through the bedroom window anymore!
