Rich-MLsRV
- Oct 1, 2020
- Colorado
- Ventana
- Freightliner
- 2020 Jeep Cherokee
Agree - it's a Cummins issue. I have the number for the Denver location so I will call tomorrow.I had it, it’s not a chassis issue, it’s a Cummins issue. You should book into a Cummins location for diagnostic. At first I had an oil pan gasket replaced, later I continued to find oil and it was a head gasket, the oil pan gasket was probably a mis-diagnosis. The Cummins facility will obviously visually inspect, in my case they used a flourescent dye to identify the source. Here’s the catch though, if they diagnose and don’t do the repair, you pay for the diagnosis. If you remain there for the repair, the diagnosis is covered under warranty. I see you have a 2016 so you probably better hop on this right away. Take pictures and try to pin down the location best you can.
