How long do you leave water in your fresh water tank?
Headhunter
Northeast PA
Tiffin
Phaeton
38ft
Powerglide
Cummins 450
2017 Jeep Sahara
Just came back from our first camping trip of the season, it was only for four days? Naturally before I left I put some fresh water in the tank, drained it and filled it up. I always carry a full tank of fresh water just in case. Naturally we used the fresh water tank for the bathroom use and clean ups but that is about it. When we got to our camping destination I switch over to city water.
When we return home I still have almost a full tank of water almost 80 gallons. My question is do you guys just drain the water out or leave it in the tank for a while? Lets say your next trip is in two weeks? leave in or drain? I always drain and start fresh, but it seems like a waste of water. Can your water become contaminated in just a week or two in your tank without using it?
HH
HH
To answer part of your question, I too carry a full tank of water in case of emergency. I've added a male hose fitting to the end of the tank drain line. I then connect a pump to it and pump the water out onto my grass so as not to waste the water.
HH
We never travel with a full tank of water (unless we will be boondocking). To me that is just a waste of fuel. We travel with under a half tank We do this just in case our next site doesn't have good water. (We test the water at each new site before we will attach a hose to it.) If we are at a park, we will not hook up to "city" water until our tank is near empty. That way we keep the freshest possible in our tank and don't waste any.
I always travel full fresh and empty black/gray in case of an unfortunate situation sidelining me. I leave it full in storage, cycle it and/or sterilize it prior to or on the first stop of the next trip using bottled water until ready.
We use our water for showering, toilet, dishes, etc... and use bottled water for consumption. I always add a bit of Chlorine when filling the tank. We leave it until the next trip. In my (uneducated and humble) opinion, bacteria and other "stuff" will grow in there regardless of the water level. So I'd say it doesn't matter...either way 🤔 Blessings
As to the question of leaving water in your tank for extended period.......you don't. There's a LOT of microscopic organisms in even treated water that can grow to a very high PPM count and contaminate it. Drain it and replace with fresh as you approach your camping site.
FWIW; When I was still in the Nat'l Guard, we were always told to drain, rinse, and refill our canteen(s) not less than every 24 hours.
Roger
My opinion: It depends on the source of your water. I’m on a well, so will empty if my coach is going to be sitting unused for a couple of weeks before heading back out. If city water, I wouldn’t hesitate to leave it in there for a month.
While parked for extended periods of time we change it out monthly. Use the water from the tank prior to the replacement.
Normally travel with about 1/2 tank to save the weight of the other 75 gallons of water 😊
Sanitize everything annually.
This is what I do also for the exact same reason.
FLSteve
I sound like the odd man out! I will drain all but 1/4 out before I hit the road, otherwise it stays until used up.
But then I fill with RO water, and filter with carbon block as I use it, sometimes use the UV light.
Same here
Hi Guys:
Thanks for the answers. I to am on a well so the water I use in my holding tank is untreated. When sanitizing people say to use a bit of chlorine? How much is a bit for an 80 gallon tank? Is there other products to us to sanitize it? Not to keen on chlorine?
HH
An alternative to chlorine, is to locate an outlet for pool supplies. They have chlorine treatments for swimming pools in form of granules. You need the very smallest packet they have. It'll last you a very long time. The packet provides info as to how much per X galon of water to use.
Headhunter,
If my math is right, 80 gallons of water is 302,800 cc. I think household bleach is typically 7%. You typically want 1-2ppm of free chlorine. Not allowing for specific gravity 100 cc of bleach should have about 7 cc of chlorine. 1-2ppm of 302,800 should be about 8-10 cc of household bleach. Please! If there is a chemist among us and this is wrong, shame me into submission.
Hi Guys:
HH
Baking soda, or ClO2.
