jwwradio
- Feb 2, 2026
- Westlake, Louisiana
- Sunlite
- MJ13
- 13'
- Single Axle
- 2008 Toyota Tacoma
Take a look in your trailer owners manual. They may indicate a place to put a jack. There may also be a marker under the trailer pointing to the jacking spot. This can be a precarious operation if not done carefully. A floor jack would be the best way to do it, but most people won't be carrying one of those around. A bottle jack is another way but make sure you have some wood blocks to give it a real solid footing.My camper, albeit, small (Sunlite MJ13) has a single axle and it quite high off the ground. I keep a small Floor jack in my truck when towing, but wonder just how easy it would be to jack one side of the camper high enough and safely to swap out a tire...View attachment 31501
You absolutely need to have a TPMS (Tire Pressure Monitoring System), especially with a single axle trailer. If you get a flat, you won't be able to feel it. Then you will be driving merrily along while your tire disintegrates, eventually destroying your wheel well and causing extensive damage.
I will definitely look into the TPMS. They tires look good, but I do know they are Labeled as "Westlake", which happens to be the name of town I am living in. However, they are stamped "Made in China".I second a TPMS. I would check the DOT number on the tires to see when an where they were is made. A lot of trailer manufacturers put on the cheapest tires they can to get it out the door. Wife and I are considering a small trailer and the first thing I would do is replace the tires. The cost of decent tires outweigh the cost of the damage they cause when they fail on the road. Also the inconvenience and danger of being stranded on the side of the road.
Just my two cents. Here is a list of DOT codes and what the mean. DOT Tire Code Decoder: Find Your Tire's Age & Manufacture Date | Tyrehood
There are others.
Dido! With the caution. Don't jack on the axle tube or you risk bending the axle.On single axle I always place the jack directly under the axle to where spring bolts are..thats the minumum lift to get tire off..on my tandems i carry a tapered block..just drive or back the nonflat tire up on it, flat is off ground.
Had bad experiences with Westlake tires..belts broke and tires deformed..I will definitely look into the TPMS. They tires look good, but I do know they are Labeled as "Westlake", which happens to be the name of town I am living in. However, they are stamped "Made in China".
Jeff W Waldrop
Excellent idea on the "dry run"Personally I feel the safest thing you can do is PREVENTION. The day after we picked up our fifth wheel, I took it to Discount Tire and had all tires replaced with name-brand tires and I stepped up one load range for extra peace of mind. And, we have a TPMS that I wouldn't travel without. It has saved me from damage in the past when I've picked up nails or screws and had a leak.
As for the floor jack, I'd be tempted to get out some day while you're home and do a practice run at jacking the trailer up and down before I had to do it on the side of a busy freeway or lonely country road.
And get those “China bomb” tires replaced. Cheap insurance and as mentioned go up at least one weight rating with the new ones. One more thought, I will NEVER stop on a highway to change a tire. I would choose destroying a tire and rim while I drive slowly on the shoulder to the nextExcellent idea on the "dry run"
LT tires don't hold up on tandem axle trailers.All great suggestions. My thoughts, get Goodyear Endurance tires on your trailer. Another option, Cooper makes a great ST (special trailer) tire too. Some folks have had real good success switching from the ST tires to LT, light truck.
To me the best PM you can do is check the tire pressure before your rig leaves the driveway Every Time! Either do the tire monitor thing, or carry an air chuck with you to keep up on the tires pressure. Carrying along a tire plug kit and portable compressor which can get you off the interstate and to town to have a flat repaired. Blow outs are worse case scenario for all RV'ers regardless of type and size so we're back to proper inflation and a good brand tire.
That being said, not following my own advice earlier in my RV travels, I put over 50K miles on my tow dolly dragging around our KIA Sportage behind our motorhome. The dolly came with cheap tires which wore poorly. I replaced after about 25K miles on them with tires that cost me $56 each, installed by a neighbors dad"s collision shop. After close to 30K miles on those tires they almost looked new when I sold the dolly (for a brand new dolly with Goodyear Endurance Tires). The key, keeping the pressure up to the recommended inflation # per sidewall stats.
