“Fresh” water
Russellvh
Forest River
Wildcat Fifth-wheel
2019 Ford F-250.
Being full time and changing Parks every couple of weeks, means I use several different hoses, as needed, for city water. I do try to drain as much as possible but I got to wondering how much mold etc. might be growing in the unused hoses between uses.
Do you do anything special to clean and / or dry your hoses when moving?
I blow through one end until dry then coil and screw itself together. I never use city water hook up or drink the water onboard.
I use My own hose. The system you tap has enough free radicals to keep the hose clear of things growing in it.
How I handle the hose supprises some people. I maintain the free radicals by coiling the hose with water intact, screwing the ends together. This keeps spores from finding there way into an open plumbing circuit (hose).
If i know my drinking connection hose is going to be sitting a while I pour a little bleach in it and connect the ends. Next time it's used I just rinse it out we'll before connecting to the rv.
I do the same plus I flush the hose and park plumbing for about 10 seconds (or until cool water comes out if we are parked in the heat) before attaching it to the coach.
I connect my hose ends together for the above reason, and for another: Here in Florida "we have bugs we ain't never going to use", and don't want some setting up residence in the hoses.
Thanks for all the responses. I guess I’ll just keep coiling and connecting together when not using them and running some water through the hose(s) to be used each time I move before hooking up. Very much a “drink from the hose” generation and grew up eating what fell to the ground or floor as long as I don’t wait over 5 seconds.
Just an FYI: When we arrive at a park that is new to us (in the US or Canada) we do a quickie test before connecting a hose. We take a large "clear" tumbler and fill it it water (after we have let the tap run for a bit). We do a visual to make sure it is clear. Then we do a smell and if it passes those two, a taste. If it passes, then we attach the hose.
This winter we plan to spend a lot of time in Mexico. We have three filters including a reverse osmoses before any think hits our tank plus we will be doing more comprehensive testing with
We have, in all of our years of traveling, only found a few that we discovered to be unusable and they were all in rural Saskatchewan.
We've been RVing for 52 years. I sanitize a new RV fresh water tank once when new and then never again. When we had separate hoses, I just "walk" the hose down, coil and connect the ends. Since 2005, we've had cord reels on our three different DP's. I just power them back in and cap off.
I've been drinking the campground water for 52 years and I'm still here. I doubt anyone can find a case where someone got ill from drinking the campground water. Our coach has a wet bay filter and most of the water we drink comes from the in the door refer water which has a filter.
X2
Yup! What you can't see can't hurt you.
Ditto for 26 years...only half of your RV experience. And, at age 76 currently...probably not going to catch up with you, but we will have fun trying...and drinking the water as we go.
In my boat, a cruiser, we stay at marinas and their water is not exactually fresh tasting. I installed in the boat, and under-sink water filter I bought at Home Depot for $20. The input and output take plastic fitting and adaptors for the existing hose was a screwdriver and wrench job. The commentors ran $6.
I change the filter element (Get the charcoal one) once a year at $12 for 2. The taste difference is very noticeable.
It should be easy enough in an RV.
Yes, I learned to taste the water before filling the tank.
I sanitize monthly due to living in a very hot environment. Use the typical blue filter and a water drop underside for the kitchen cold line. Water taste fine and never an issue.
If you use a filter, be it one you hook up to supply the entire trailer, or one for just drinking water.....if you store it between uses, you must put it in a refrigerator or you will risk contamination as bacteria can grow inside the membrane.
