Question What make/model outdoor grill do you bring?
JeffandPam2003
North Carolina
Renegade
Verona LE
40'
Freightliner M2-106 Plus
Cummins L9
2027 Jeep Gladiator Mojave
Hello, while we're awaiting our Verona LE 40 LRB my wife asked me what kind of grill was I going to outfit the RV with... I said a good one :D.
Since the Verona LE is an all electric (no onboard propane), I thought I should ask around to get an idea of what everyone else is using. Do you charcoal grill, use a portable propane grill?
Thanks
You are going to find bushel basket full of fans of the Ninja grill. It is electric with a smoker function that uses wood pellets. If you prefer a propane grill, consider getting the five pound bottles to operate it. A couple of them will last through several meals and they take take up almost no space underneath.
I use a PitBoss portable. It will both slow cook and grill.
I used to use charcoal but since getting the PB I don't anymore.
The one thing about the grill is you have to a little clean up afterward.
Thanks
I would love Ninja but we boondock lots so no "lecricity. I would also love to charcoal but too messy for DW so we propane. If you can Ninja that would be my choice. We have a Napoleon travel Pro 285. It works well and is fairly compact.
Thanks
Not knowing the voltage, does it have an inverter?
Yes, it has two 3000 watt inverters; albeit, as I understand one of the 3k inverters has 1 of the A/C units wired to it.
Blackstone 17", plumbed into the rig.
I got rid of the little grill because it was a greasy mess and a pain to clean all the grates and under the flame bar.
I have the older Magma kettle grill, which I have used for the past 35 years. ALL stainless steel, and cleans easily with E Z off oven cleaner.
I bought the assembly ($18) to hook to a LP 10# tank. The 1# bottles are now $8; the 10# tanks fills for $18.
Just burned up a Cuisinart tabletop grill while hunting, the kids got it for us and I never liked it. Much to hot even on low. Fellow hunter gave us a Weber tabletop unit he never used. It will need a pan under it to catch the grease, and I imagine it will be greasy mess. Next up is the Coleman 285 when we get tired of cleaning up grease. But how do you eliminate grease when cooking?
we have a Colman tabletop 225 grill and love it. easy cleanup. do not put water in grease pan just wipe it out. grease coating keeps it from eventually rusting out. 11,000 btus great.
Small weber kettle. Its about 14” in diameter
