I agree but I wouldn't be complaining about 13mpg, that is my mileage pulling a trailer of any size with a frontal area, using my modern 16' RAM. Advantage comes when not towing 20 MPG.Hi Kevin
Thank you for the reply
Introducing computer controlled technology into my old Chevy sounds a little over the top
A six speed typically has at least one over-driven gear with 5th usually being 1:1, with some having two overdriven gears with 4th being 1:1. Since you already have 1:1 in third, and don’t want overdrive, swapping to a 6 speed (if its even possible) would really only net you one extra gear, closing up your ratios a bit which might improve performance under some conditions, but since you wouldn’t be using over-drive much, probably wouldn’t improve your MPG, which as Kevin said, isnt all that bad anyway. And if you did want to improve mpg a bit, an OD unit (such as a Gear Vender OD at around $3200) would do it for you and would be a fairly easy job.Hi Everyone
I have a 1979 351 G30 Coachmen Surrey, in the UK
I get about 14 mpg out of my 3 speed automatic gearbox, does anyone have experience of installing another one, say 6 speed?
I am aware of overdrive upgrades, but would like a lot more
Thank you
Tony
Thank you for thisIt would cost more but if it were me I'd be looking for a "4L80E". Not only will you gain a fourth overdrive gear but they are WAY tougher than a 700R. 700R's are pretty iffy in half ton trucks if you ask me. 4L80's can be found in 7.4 liter 20, 000 pound class A's over here. And they work fine I don't believe the factory put any 700R's or their electronic successor, the 4L60E in any truck or van that is rated as being a one ton like a G30. They evidently didn't think they were robust enough either.
To use a 4l80E, among the other changes, you would have to buy the standalone computer and harness that makes it work without a factory computer. Those run right at $500. Not a cheap undertaking all told and I doubt you save enough in fuel to pay for all that. Even knowing your petrol is a LOT higher in price than ours.
Part of my shopping criteria when I was looking for my older coach (1993 model) was that I wanted it to have overdrive. It does. Spends a disappointingly small amount of time actually in it, but it's there.
Whatever you get you will need to make sure it is not computer controlled. That of course is unless you have the ability to program the controller.Thank you Kevin, Rich
The more I investigate this, the more I am learning
Currently I have a TH350 gearbox, the later generation of Chevy has the 700R4 gearbox, which will bolt straight on with a reduced prop shaft
This will give a top ratio of 1:07 which is equal to 6 speed boxes that I have seen
Now I need to find one and get it shipped to the UK
Changing the content of this post for this reply only, I am reading that it may be easier to upgrade my MII than the Chevy G30, which wasn't my original intention and that the 4R70W will need the electronic controller?There are computer "kits" for the more popular transmission retrofit swaps. Usually from $500-750 for a standalone module, wiring harness, and various bits to make it work. Once again, the 4L80E kit for this application runs about $500.
Though Rolls and even a couple of mid-1990's Jaguars used 4L80E's, this doesn't mean one will bolt to the back of your engine. They don't have swappable bellhousings. The bellhousing part that bolts to the engine is the actual case. I know they made a few different cases for them. Now whether they made some specially for the RR and Jaguar applications or they were a standard Chevy configuration I frankly do not know. Not so many of those cars over here. Ideally you'd want one from behind a 5.7 Chevy/GMC truck or van.
I've not seen one in a Ford. You could do that but it involves cutting the bellhousing part off the case and machining bolts holes to attach a custom bellhousing. Such bellhousings run $500 each. No idea what the case machining would cost.
You have a Mustang II? Best fit for adding overdrive to one of those is to swap to a 5 speed. Reason being that the automatics are a bit large and the car is small. Manual transmissions tend to be slim and trim. The go-to automatic overdrives for those are the AOD or the 4R70W. I haven't done one myself on a '74-78 car (my Mustangs are older and newer) but I understand you have to modify the transmission tunnel a bit (big hammer) and trim off some non-essential protrusions on the transmission case. And it will still be a very tight fit.
I like AOD's for being more simple and not requiring a controller kit but for the trouble I suspect you might have to go to anyway I recommend spending a bit more for a 4R70W setup. Depending on what you can actually find, of course. No way you'd ever recover the money it would cost with the gas savings in a car. But when you are on the highway and it drops down into overdrive at about 50 mph it sure is sweet. I'm addicted to overdrive and want it in everything nowadays. Manual or automatic. I bought a VW Caddy years ago (driving it today as it happens) and one of the first things I did was source a five speed from a Golf to swap into it.
