duo-therm
  1. S
    Dometic Duo-Therm 15KBTU A/C - Freezing Up Issue
    I can't be the only one with a Dometic Duo-Therm 15KBTU A/C Unit that invariables freezes up when the outside air temp drops to about 78 degrees F or 75 degrees F. The unit runs wonderfully! If it's 80 degrees F and hotter, it is a flawless unit! But SO often, I go to bed, at night the temp...
