#electrical
  1. N
    Question Right Brake & Turn Signal Dead After Attaching Tow Dolly – Fuse Box Slot Empty?
    Hoping someone here has run into this before and can point me in the right direction. I have a 210 Popular (Chevrolet chassis) and recently hooked up a car tow dolly for the first time. After doing so, I noticed my right brake light and right turn signal on the RV completely stopped working...
  2. Cummins Onan RV Generator Gasoline QG 2800i for sale $2100
    Nearly new, Cummins Onan RV Generator Gasoline QG 2800i 2.8HGLAA-8303 for sale $2100 This generator was installed on a local hospital's COVID testing van. It was used lightly (only 39 hours) and well maintained by their in-house mechanic. It is very clean inside and out and includes a custom...
  3. Xantrex FREEDOM SW 3012 INVERTER/CHARGER for sale $1200
    Xantrex Freedom SW 3012 Inverter/Charger for sale. This has a pure sine 3000 watt inverter output as well as controlled charging for a battery system. This unit was installed in 2020 into a local hospital’s van used for COVID testing. It has been used for less than 50 hours and is like new. A...
  4. B
    Electrical Fire: Need Help Rewiring
    Hey All- I have a 2019 Forest River 23MK that I rented out over the Independence Day Holiday. Unfortunately the renters didn't pay attention to the slack in the 7-pin wiring harness and it dragged on the ground causing a lot of heat and small fire. Almost all of the wiring north of the frame...
  5. F
    Not enough electrical outlets
    Perhaps the only complaint we have about our camper is that we have just 4 electrical outlets. We are wanting to mount some small fans in our sleeping area, but the outlets are far away. Currently we rely on multi-plugs where we can, but we are looking for a simple solution that hopefully...
