relay switch
  1. T
    Battery Boost Not Working
    The battery boost is not working batteries got drained and tried waiting a good long time for it to show charging from the boost and it did not charge, I have had to put the batteries on a charger. I checked the ausillarynstart fuse and it’s fine. I’ve narrowed it down to the relay solenoid in...
  2. T
    Dash AC works, blows cold but compressor drains battery when not on.
    Just like title says, saw a whisp of smoke once when connecting it back, so I either keep the compressor disconnected or starter battery drains, any chance it's a stuck relay, can I test the relay using a 9 volt battery? Could it be the compressor is going bad? thanks for any help.
