Rowdy22
- Mar 13, 2022
- Empire Alabama
- Keystone
- Springdale Mini
- 22 ft
- Yes
If you have an inverter they will. Plug a hair dryer or portable light into the 110 socket and check it out.I am a newbie to RVing and was wondering if I am running on DC power will my outlets convert to 110? Or do I need to purchase things that run off 12v?
Good morning. The solar panel jyst charges the battery. It won’t provide 120 volts to any plugs.I purchased a 2022 Keystone Springdale Mini, 22 ft. It has a solar panel on the roof. I do not know the wattage. I know the receptacles say solar power. I haven't tried plugging anything into it yet. Also, if hooked up to shore power I have read to disconnect from the 12v, but I don't see anything in the TT to do so.. I am new to RVing so not sure about a lot of things electrical.
Technically I can visualize the system when connected to shore power the batteries are charged from the CONVERTER and the outlets are supplied with 120 VAC. When disconnected from shore power, the system reverts to battery power, charged by the solar panel, and the system switches to an INVERTER to supply 120 VAC to the outlets.I purchased a 2022 Keystone Springdale Mini, 22 ft. It has a solar panel on the roof. I do not know the wattage. I know the receptacles say solar power. I haven't tried plugging anything into it yet. Also, if hooked up to shore power I have read to disconnect from the 12v, but I don't see anything in the TT to do so.. I am new to RVing so not sure about a lot of things electrical.
Depends on what you own, some rv's do and some don,t. Ck with a repair facility............I am a newbie to RVing and was wondering if I am running on DC power will my outlets convert to 110? Or do I need to purchase things that run off 12v?
