Mckenzieguy
- Mar 11, 2021
Good day everyone,
So my wife and I purchased a 2002 Presidential fifth wheel last month. We finally got the 18k hitch installed and two days ago I brought it over to the house. Prior to that I had my electrician install a 50amp RV panel next to our meter base. The fifth wheel is located 60ft. from the RV box so I ordered a 50ft. extension online which is designed for such use. I currently have 50 amps and 240v at the 3 pole 4 wire connection outside, plus 240v at the 50amp breaker in the ac panel.
Here is my problem and most likely I'm missing something. None of my appliances that run off the panel are working. I checked the amps comming into the 50 main and it's correct, but I'm getting low amps on every other 120v breakers..
The prior owner is trustworthy and have known for years and said he never had issues, just locked it in place and boom power. Our previous travel trailer, 120v was the same, pug in and away you go.
Am I missing something in these Presidential fifth wheels?? BTW. my electrician is coming tomorrow to take a look. The RV dealer who installed the patriot hitch is two months out on any service appointments.
Thank you.
Thank you.
