2008 American Tradition
eller419
We recently purchased a 2008 American Tradition. While driving it home, we noticed the coach was leaning towards the passenger side in the front. The prior owner said it was a minor adjustment and that he had just changed the batteries. The coach sits level when aired up, but when it is put in the travel mode the air deflates on the passenger side makin it lean.
Does anyone know where to begin to diagnose and fix this problem. We are in South Florida, so it is a good 2 hour ride to get to a Spartan authorized dealer.
looking to solve same problem you get any help? Pensacola here
Try leveling the coach on Air and then travel mode . If in travel mode put the Power Gear “Valid” in air mode and manually raise the low side to see if it will level out. Be sure you’re on level ground first. May need to reset the power gear panel also
I have a 2008 Tradition and will always release all air at campsite then auto level. Next day when departing push travel. Some times it will not raise to standard road travel height right a way but I believe at 30 MPH the air ride system automatically raises to road level height. Is it possible the Valid Power gear needs reset/calibrated?
