2013 Palazzo 33.1 Help
Chuckfish
New here. Help pls. Is the fluid reservoir in my front bay passenger side the power steering unit ? I think so. The owners manual refers to Dextron 6 ATF for power steering fluid. In a separate other section it lists Dextron 3 and 2. I need fluid. What do I do pls ? Also, is the fluid synthetic ? The fluid is pinkish in color. Thx in advance.
There should be something printed on the lid of the reservoir that tells you what it is and what type of fluid to use.
That makes too much sense. Nothing to be seen though. There are high pressure lines. Fluid tastes like ATF and is pink.
"Tastes"? I've done engine work. Yet to taste fluids coming out of one. I wish you well on your mission. :)
