Resolved 2015 Coachman Freedom Express 192RBS Rocker switches.
DEB1130
I purchased a 2015 Coachman Freedom Express 192RBS from someone who knew nothing about it. I'm would like to know what the third rocker switch by door goes to? One is for ceiling lights next is the awning light and the third one doesn't appear to do anything. I have no manuals.
Thanks
Possibly for a light on the other side of the rig for night set up. ?‍♂️ Welcome, enjoy your new rig.
Might be for the outside outlet.
You can et an owners manual and other information for your 2015 Coachman Freedom Express 192RBS here:
Check all outlet inside and out but nothing seems to be effected by switch.
I have looked at online owner's manual but I haven't seen anything on switches
Thanks
DB
Have you called Coachman to see if its technical support staff could help you with this? Might be worth a try.
Could be the switch for the cabinet light above the couch.
Problem solved. Thought the outside door light was trailer marker light and that it was working when truck was hooked up. It wasn't but it was burnt out. Replaced bulb works like a charm. Now I have working light by door. Thanks
