I have a 2020 F350 dually w/7.3 gas engine. It tows a 2018 Keystone Montana 3791 weighing in at around 16k lbs. I have almost 20,000 miles on the truck and have been watching the front tires wear on the outer edges. I’ve had it in for alignments twice. First Ford dealer said it wasn’t out of alignment. Second Ford dealer did perform an alignment but said it was only slightly in need of alignment. The negative camber problem persists so I recently took it to a third Ford dealer. After asking me questions neither of the first two dealers asked, he said I shouldn’t bother with alignment, I needed an air suspension for the rear to keep the truck level. He went on to describe that, while I am operating well within the specs for the truck, towed weight tends to lift the front of the truck into a negative camber that having it aligned without that weight — ie, having the trailer attached — would be wasted money. So, I’m on the hunt for an after market air suspension that will remedy my problem without, hopefully, breaking the bank. Otherwise, my front tires are “consumables” to be replaced every 15~20 thousand miles. Not to mention the safety and drivability issues having your front wheels floating across the road surface suggest. So, I’m seeking any experience others may have in this area and recommendations as to what kind of product will help here.
