MOD Alcohol Mist Spray Dispenser
MichaelMdG
Baton Rouge
Mountain Aire (4543)
Freightliner
Cummins I6 Diesel Pusher 500 HP
2020 Jeep Grand Cherokee Summit
One of the actions to help prevent the spread of Covid-19 is to clean your hands often either with soap and water or a hand sanitizer.
I would like to install an alcohol mist spray automatic sensor dispenser (on batteries) outside the motorhome door and be able to remove it when we are driving.
I am thinking of using the 3M dual lock reclosable fastener. Will it be easy to remove the fastener when we don’t need the dispenser anymore? I am really hoping that I only need this mod for this year.
Where do you intend to mount this @MichaelMdG? You may also want to consider an air purifier with UV light in the coach. I have an Air Oasis system which I'm very happy I bought before this pandemic came about mainly for air quality in AZ.
Thank you Neal. I will definitely look into the Air Oasis System.
I was intending to install the dispenser next to the front door entry touchpad so you can use it before you open the door.
Michael
Thank you Neal for the suggestion. I have ordered the G3 Series UV Ionic Air Purifier - 3000G3 (600 sq.ft.). I think that should work for the whole motorhome.
