- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
One of my fav gadgets is the Amazon Echo which I have everywhere and the Echo Show 5 is ideal for your RV bedroom as a night stand clock and all the other features Echo's provide such as music, home control (smart plugs and other things like WiFi thermostats in your S&B, lights, etc.). I created an under cabinet mount and 3D printed it so it is 3M 2 inch dual lock reclosable fastener up under my bedroom TV area so it's not taking up counter space and is visible from bed, etc. A problem though has been it's not sensing light properly maybe from my mount or maybe due to some other issue such as mounting under a cabinet instead of sitting on a table. It should show orange text at night but it's been lighting up and showing my select background images, etc. Enough already, I had to figure this out. So I did:
Go to
Note: Amazon does not handle time zone changes well. When changing the device location which changes the time zone you would think the time windows for do not disturb would remain the same. They don't! They shift by the time zone change difference so be sure anytime changing location to check your do not disturb and night time windows.
Go to
Settings > Home & Clock > Night Mode
. Review the settings here and set a time window that is night, the scheduled option is key here. The next critical item is near the bottom with the option of using the scheduled time or sense light. The sense light option is the problem so switch this to the scheduled option and the problem is solved.Note: Amazon does not handle time zone changes well. When changing the device location which changes the time zone you would think the time windows for do not disturb would remain the same. They don't! They shift by the time zone change difference so be sure anytime changing location to check your do not disturb and night time windows.
