Rbtr8er
- Dec 5, 2020
- Longview, WA
- Monaco
- Executive
- Chev Malibu LTZ
We have a 2002 Monaco Executive, purchased in 2015. During two year trip around country the Aqua Hot worked great. Mainly used "furnace" and "cool" settings. Never used "Heat Pump" setting. Starting in Oct. 2019 "furnace" setting quit working. Had service work, including Aqua Hot, done at dealer in Junction City, OR.. Service advisor informed us the Aqua Hot was repaired and we needed to set it on "Heat Pump" to heat the coach. Told him we had never used Heat Pump setting and had great results for the past four years. No change made by service. We now do not have heat via "furnace" setting. Not good in cold weather since "Heat Pump" setting does not work at below freezing temperatures. Seeking possible reason furnace setting does not work. Unit is Diesel fueled. Is there a valve on the unit itself that may need to be turned on? Could it be the Aqua Hot switch in the coach. (The switch for this unit is only a "On" "Off" switch, not Diesel, Electric, dual switch.) Small red light on Switch that shows it is on does not light up at this time. We have taken the coach to another dealer for repair of the Aqua Hot problem and did not get any better result.
