I have a new Thor class A Outlaw and just discovered that the light bar on my front awning has quite working. It simply flickers very faintly. Closest dealership 86 miles away. Would rather not go that far if there may be a easier fix. Any thoughts would be appreciated. Thanks
my brand new Thor ACE 33.1 awning light quit. I started by looking for where the power was.. and wasn't, nearly the first thing i looked at was the switch.. i pulled it out to see if it had power on its pins. and low and behold the connector from the switch to the awning had just fell off
check fuses
is there power from the switch to the awning
if not, can you hot wire the lead going to the awning
