Airxcel 46515 basement air installed about 3 years ago. When I turn it on the inside blower starts, about 30 seconds later the thermostat clicks, then compressor 1 may or may not start. I'd say maybe one out of 15 times it starts - runs fine, is cold. Compressor 2 never follows even when compressor 1 does start. I have followed diagnostics down to checking relays. Don't know how to test relays and couldn't find one locally so I took the relay from compressor 2 and moved to to compressor 1. compressor 1 still did not start. It doesn't seem likely that both relays would be bad but I suppose it's possible. I also tried replacing the lifelife which didn't help either Next on diagnostics is check run capacitor @ check motor windings for open ground? Don't know how to do this either. A/c is out of motorhome and open, but wiring is still connected. Any advice appreciated! Can't seem to get anyone locally to work on it......
