team bradfield
RVF VIP
- Nov 9, 2022
- Dutch Star 4081
- Sparten
- 450 cummins
- 2022 Grand Cherokee
I was thinking that also, I will fire it up today and see if that makes a difference, batteries show full voltage, I'm used to the resettable breakers on my past 5'vers but this doesn't appear to be the same issueAre you trying with the motor running?? The only thing I can think of is the amp draw on the batteries may be a lot higher with things being that cold. Do all batteries show full voltage??
I'm in agreement, as it starts to move, then stops it seems to have power, I did get it to fully retract, I don't have a trip planned until spring so I will probably wait till it warms up a bit before exploring more. thanks for your helpRats, that is all I have. From here I would think mechanical issues rather than power issues, but likely means getting under the bed area to see the motor and various linkages to see what is binding up. Sorry your dealing with this in the cold!
thanks, thats a good place to start, pictures help a bunchHopefully it's not the shaft between the motor and the gear like mine...we were able to push the slide in and lock it. Fixed at Bish's in Oregon. Probably someone mechanical could fix it...I'm not. It was easy to see...
