Best 30W Lithium Powerplant that will plug in to my teardrop unit
Dstine
Looking for a 30W Lithium generator (no gas) that will plug directly into my teardrop trailer; enough to run a small AC unit if needed.
Do you mean 30 Kw?
If you want to run your teardrop from a battery pack just buy an EV like the ford lightning or Rivian pickup. They have built in inverters that you can plug your RV into.
You want to run an A/C off of a battery pack? Good luck. Battery technology isn't good enough (yet) to do that for any reasonable amount of time. Never mind that the 30W you're asking about isn't enough to do it with. The A/C unit is probably rated for not less than 1200 watts.
You'd need a massive pack to run an A/C long enough to do you any good. Even then, you'll need some method of recharging.
Now, with a large solar panel array, you might be able to swing it.
Roger
Roger
Oh it can be done but not with an onboard battery pack in a small trailer. People are successfully doing it by plugging their small trailers into their electric half tons. Every few days just head to a DC fast charger and recharge. Rinse and repeat. But of course it all starts with buying an electric half ton from ford or Rivian.
Cheers.
