- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I think I was pretty clear. As long as the TV can accept the hitch weight within the GVWR of the TV things like the CGWR become meaningless with a powered trailer attached. However the TV still needs to be able to handle the CGWR of a powered trailer to handle those situations when the powered trailer is out of charge or has a problem with the traction motor system.So your/they are saying 800 pounds tung weight isn't an issue when the vehicle fails to have the load capacity to support it?
Very enteresting!
Guys! Your argument for buy a big enough tow vehicle (load capacity) just got proven wrong by a handful of dreaming techies!
I'm going looking for a larger fifth because tung weight is not important anymore!!!
Yah. I did like his explanation on what happens when the LFP battery is empty. A set of contacts open and it just becomes a normal towed trailer.I think I was pretty clear. As long as the TV can accept the hitch weight within the GVWR of the TV things like the CGWR become meaningless with a powered trailer attached. However the TV still needs to be able to handle the CGWR of a powered trailer to handle those situations when the powered trailer is out of charge or has a problem with the traction motor system.
So! The founder in your video did a good job of stating his goal. In a nut shell, he saw the need for a range extender!I think I was pretty clear. As long as the TV can accept the hitch weight within the GVWR of the TV things like the CGWR become meaningless with a powered trailer attached. However the TV still needs to be able to handle the CGWR of a powered trailer to handle those situations when the powered trailer is out of charge or has a problem with the traction motor system.
I would think all the half ton EV’s on the market are capable of handling this unit.So! The founder in your video did a good job of stating his goal. In a nut shell, he saw the need for a range extender!
Back in the day EV enthusiasts chopped a front wheel gasser to trailer behind for trips. I think that is why hybrids were made.
An engineer worth his salt studies all aspects of a project before he starts the development stages!
Looks like only a few EVs are really up to the task based on tongue weight. The pendulum effect known for centuries precludes any workaround.
A Camper’s Guide to Electric Vehicle Towing Capacity | TAXA
Do you have an electric vehicle that can tow a trailer? If so, what are your options for a fifth wheel? Find out how to get the right camper for your EV.taxaoutdoors.com
Like everything else, people find it hard to cut their losses, when they see through the lie!
I don't see this product having any resale value within a year of release!
Of course, that is my opinion.
