arties45
- Feb 7, 2021
- Imperial Mo
- Coachman
- Freelander 21QB
- 24'
Do you think I can pull a pop up? The Max Gross Trailer Weight is 4500 lbs. and the tongue weight is 675 lbs.A very very small one.
That would be about right. I think you'll be OK unless you are climbing a long steep grade, then your little 4 cyl and transmission won't like you very much. Keep an eye on your temperature gauge!!!Do you think I can pull a pop up? The Max Gross Trailer Weight is 4500 lbs. and the tongue weight is 675 lbs.
