bowpulpit
- Oct 15, 2020
- Monroe, GA
- Ventana LE 4037
- 40' 10"
- 2011 Jeep Liberty
Purchased 2 months ago a 2016 Ventana LE 4037 on Freightliner Chassis.
After starting the engine the display panel always reads "Low Battery".
Checking the Magnum panel, chassis batteries reads 12.8 volts (house batteries at 13.6). I used a volt meter on the both chassis batteries and they each read 13.6 volts.
Today for the first time after starting the engine, the dash volt meter cycled a couple times down to about 8 volts which caused the "Low Battery" readout to display momentarily then it would bounce back up to about 13 volts. It did this 2-3 times then stopped.
Have no clue why I can check battery volts at 13.6 then get "Low Battery" warnings.
Anyone have a idea what to look for.
Thanks
Thanks
