emerald 34
- Nov 25, 2022
- Mentor ohio
- Coachmen Mirada
- Ford
- Ford v10
- Single slide
No problem. I am not sure how your class A is set up but you will want to purge your water tanks and lines of the residual water. I use a air compressor set at 45 psi and open my low drain points and fresh water gate valve then put air into the lines to purge as much as I can. Then I set my Nautilus system to winterize and start pumping in my antifreeze (RV grade) and then systematically go inside and open each faucet independently first cold then hot until the pink stuff flows. This includes any outside kitchen faucets or spray ports. You will need probably about 4-5 gallons of antifreeze to perform this. As to your hot water heater……it’s subjective whether to run antifreeze through it or not. Mine is a tankless so I just remove the drain plug and filter and drain water but not run antifreeze through it.No sir. Did not know that.
