- Feb 18, 2020
Well it happened again. The dash AC compressor locked up. First time was when I had 5K miles on it and on our first long trip.
Now I have 35K miles and it has happened again.
If you get warm air out of the dash vents with your AC on, turn off the AC immediately. When the compressor locks up, the clutch tries to turn it and soon the belt starts smoking and sparks emit from the clutch. If you don't turn off the AC, the belt will break and in my case, it is the same belt driving the alternator. In an emergency you can get a shorter belt and bypass the AC compressor.
Has anyone else had this problem? I was told that Freightliner got a bad batch of compressors in 2016.
