Dash switch removal
Soniccruzer
Mountain Aire
2007 Toyota Tacoma, 2006 Jeep Wrangler Unlimited
Generator dash switch may be bad. Switch on generator works but not dash. How do you remove the switch to check connections? 2018 MA.
They release from the back side by compressing the tabs. Not sure if top of your dash has the removable panel. If not you maybe can access by removing the drawer.
Thanks Bill. I did get to the back of the switch panel and all the connections looked good. I’m trying to research how the remote switch connects to the generator to check that connection. If that looks good I’ll look at replacing the switch.
