jagpot
RVF VIP
- Nov 17, 2020
- California
- King Aire
- Spartan
- Cummins
- Jeep Wr Sahara
You coach definitely has a DEF head that controls DEF fluid to the exhaust system but I don’t believe it has the sensors that are part of the head ”system”. It’s the sensors that are causing most of the problems not the head itself.
Thanks for your response. In the four times this "LOW DEF" message has gone off the tank was 1/2 to 3/4 full. We simply filled it the rest of the way and turned the engine off,restarted and were fine. It has not happened in a while now but we fill it when we diesel up and watch it drop one bar at 3/4, one at 1/2 and one at 1/4. We try not to get to one bar. We had the NOX sensor replaced but continued to have problems after that. Keeping our fingers crossed.For a 2014 coach, even if its a mid-2013 chassis, it will have a DEF head, but will have sensors for only DEF temp (to control the tank heater in the event of very low temp to prevent freezing), and DEF level - most likely a mechanical float driven sensor.
The majority of problems seem to be centered around the DEF Quality sensor found in 2016 and later systems. That doesn't mean you wont have problems, but if you do they are easier to address.
Im curious: were your “low def“ warnings a result of a low tank level, and did they resolve with filling, or were they erroneous, and if so, how were they resolved?
Ive resolved “low DEF” warnings (with 3 bars showing) twice by adding more DEF. Both times (I had two others before I made this connection) occurred early in the morning after overnight temps in the 20’s. DEF is supposed to be ok down to 12 degrees F, when it will start to turn to slush, but I am working on a theory that it may freeze in the lines or on the metal parts of header assembly at temps somewhere above 12 degrees (when the DEF tank heater would not be active) and is resolved by adding relatively warm DEF.Thanks for your response. In the four times this "LOW DEF" message has gone off the tank was 1/2 to 3/4 full. We simply filled it the rest of the way and turned the engine off,restarted and were fine. It has not happened in a while now but we fill it when we diesel up and watch it drop one bar at 3/4, one at 1/2 and one at 1/4. We try not to get to one bar. We had the NOX sensor replaced but continued to have problems after that. Keeping our fingers crossed.
Actually this may blow your theory up. One on the way home from Vegas with outside temps of 114. Other times perfect temps 70-80. The fill seems to answer the call though.Ive resolved “low DEF” warnings (with 3 bars showing) twice by adding more DEF. Both times (I had two others before I made this connection) occurred early in the morning after overnight temps in the 20’s. DEF is supposed to be ok to 12 degrees F, when it will start to turn to slush, but I am working on a theory that it may freeze in the lines or on the metal parts of header assembly at higher temps (when the DEF tank heater would not be active) and is resolved by adding relatively warm DEF.
Did either of your episodes occur at low temps? All four of mine did.
