Question Discount Tires Error ... Any Recourse ???
thinkntravel
In 2019, went to a Denver Discount Tires and asked them to replace the Goodyear OEM G tires on my 40' Cedar Creek 36CKTS ... about 18,000 lbs GVWR. They said they carried the tires ... installed them ... I paid the bill. Mind you, I don't know a "trailer tire" from a hot fudge sundae ... presumed they installed the right tires. Went back to that same store today to see if I should replace these tires. The Assistant Manager told me "truck tires" were installed on my rig ... not "trailer tires." Does this matter? What should I ask them to do about this mistake? Has this caused any damage to my 5er? Advice appreciated!
No harm done! Truck tires have more aggressive tread! I believe there is a difference in tax structure!
Trailer tires are constructed differently to allow for more side-ways force. Truck tires do not have the same construction.
Trailer tires also tend to sit more, which is factored in.
Not sure where the reputable articles were that I read about this years ago.
Using truck tires usually won’t hurt the trailer, they just won’t last as long.
No problem, as long as they aren't China bombs
I think the fact that you have had them for 5 years lets you know there is no problem with them. These tires are made for specific loading depending on vehicle type but in many cases as you have seen will function in other applications. I would still always recommend the right tire for the application.
