- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
There was discussion sometime ago maybe on another forum about door closing on Newmar coaches, some requiring a slam for the travel position, etc. Some have adjusted the lock catch via the PTL web site and a different catch that some may not have which I bought and have not and most likely will not install (too much effort and some risk). I got the shorter bumpers that go between the door and screen door from PTL.
The problem I've experienced with the shorter bumpers is it is allowing some play between the door and screen door which can cause some rattling. Obviously this all depends on your particular setup but for me the shorter bumpers were not an improvement. When my outer door is shut, which does take a bit of a slam effort, I want the bumpers touching and pushing against the screen door assembly to avoid any rattling while driving.
Moral is shorter bumpers may not be the best fit, there is a reason Newmar installed the longer bumpers and in my case it was the right choice.
