Electric brake controller
newmarokie
southern oklahoma
newmar
Dutch Star 4018
40'
Freightliner
450 hp Cummins
2017 Colorado, 2013 Dodge 1500 quad cab
Does anyone know if a 2019 Dutch Star is pre-wired for a brake controller? I haven't crawled under the dash and looked, but if someone knows they could tell me exactly what to look for.
For those that want to know, there is a loom under the dash with a six wire pigtail and plug. battery +, instrument panel, brake, brake control, ground, and ignition, You can unplug the pigtail and solder the wires for your brake controller on a bench. The hardest part was mounting the bracket and attaching the control in the tight confines.
This is a 2016 Ventana on an XCR Freightliner Chassis. I would climb under the dash around the steering column and look for this bundle. It will be plugged into the harness, not loose like in this photo. But still zip tied in a bundle. The schematic is being used as a placemat. Hope that helps.
yep, that is what i found. The controller is in and functional.
