shursnap
- Nov 3, 2022
- Safari
- Sahara
- 36 feet
- Cummins Diesel
I have a '96 Safari Class A RV and I'm trying to figure out why only part of my electrical works at a time except when the generator is running. When the generator is running everything seems to work, but the dining area light flickers every 10 seconds. When the 220V cord is plugged in about half of the electrical in the RV works. When that cord is unplugged and just using the inverter, the other half of the electrical works, but not most of the things that work when the 220V is plugged in. Since it all works with the generator, but not when plugged into 220V is it an inverter issue? If so, why doesn't the 220V bypass the inverter to run ALL of the 110V stuff in the RV? Any help would be GREATLY appreciated. Seems like the answer is probably obvious to someone who understands, but I'm not figuring it out.
