electrical
fletchmo86
We have a 1976 Fleetwood Prowler. I had to purchase batteries and connect them for 12v system. The only two items that have power right now are the range fan and light. No other lights work. Any ideas would be appreciated. According to the manual that came with the camper the 12v system should power lighting, water pump, recirculating toilet, and other 12v accessories.
We did check all fuses and they all are ok.
thank you
Did you forget to turn on the battery cut-off switch?
I'm not sure if this camper has one...1976 Prowler by Fleetwood. I will check the literature that came with the camper.
The batteries usually feed a fuse panel somewhere in the coach. All (or most) 12V DC items should receive power thru fused connections from that panel. Check if the panel is getting power and is grounded. Than check all the fuses. That’s one way to start troubleshooting.
Did you check the power going into each fuse or just the fuse itself?
