Jim
- Dec 18, 2019
- North Carolina
- London Aire 4551
- Freightliner
- Cummins / I6 Diesel Pusher 600HP / 1,950 ft-lbs
- 2016 Jeep Rubicon
Like most diesel engines, my coach has a compression brake. (CUMMINS 6C 8.3 330hp ISC Turbo Diesel with 330hp. ) I’ve heard it called an “engine brake”, “Jake brake”, or other names as well. From reading, it appears there is a difference between the compression brake on my coach, and the Jake brake on an 18-wheeler. But regardless of the name, the result is to use the engine to slow the vehicle down and save the actual brakes.
Since this is the first vehicle I’ve owned with an engine brake, I’m curious if I’m using it correctly, and to what extent I can use it without damaging the engine.
When leaving home, the highway descends from 4,000 foot to 2,000 foot elevation over a distance of about 5 miles. The signs say 8% elevation drop but I swear, it looks like a roller coaster ride from the top. I start my decent about 25 mph and push the “brake” button on. The braking is quite evident and when the coach starts to exceed the 25 mph, I touch the foot brake just a little bit and the coach slows back to my desired speed.
When the coach is going down these steep grades, the engine brake starts to bring the RPM’s up, and when they reach (what I consider to be) an uncomfortable point, I depress the foot brake until they come back down to where I’m comfortable. Repeat, repeat, repeat.
Is this the correct method? As I said, this is my first encounter with an engine brake and although it seems to work well, I’m not sure I’m using it correctly.
