EdMathis
- Jun 10, 2023
- Fayetteville Nc
- Coleman Lantern Lt
- 17B
- 17 ft
- The one that comes with it
- 2022 Toyota 4 Runner
You can purchase a 30 to 15 amp adapter from just about any RV store. They are quite inexpensive. Once you have that you can use any "out door rated" extension cord. 15 amps will allow you to use lights etc and if you have a battery charger integrated into your system, then your battery will charge as well.I want to be able to plug my Coleman lantern Lt 17b into my house while loading or unloading and cleaning. I don’t have a 30 amp receptacle, I have the 50 to 15 amp dog bone What gauge extension cord would be good for this?
30 amp cord is 10 awg.I want to be able to plug my Coleman lantern Lt 17b into my house while loading or unloading and cleaning. I don’t have a 30 amp receptacle, I have the 50 to 15 amp dog bone What gauge extension cord would be good for this?
I would suggest that you NOT run your AC using just a 15 amp service. You state that you do not have a 30 amp service from your house. As mentioned by others, an overload can easily cause a fire. If you want to run your A/C you should have a 30 amp service installed and then make sure you use an extension cord that is rated 30 amp as well. Kevin gave you the wire gauges required.Thanks y’all will I be able to run the ac a short period?
Thanks everyone , that’s what I needed to know going to get a 30 amp put in at the house.I would suggest that you NOT run your AC using just a 15 amp service. You state that you do not have a 30 amp service from your house. As mentioned by others, an overload can easily cause a fire. If you want to run your A/C you should have a 30 amp service installed and then make sure you use an extension cord that is rated 30 amp as well. Kevin gave you the wire gauges required.
Darrell
In the mean time! Your house breaker will protect your house wiring. You would only risk a fire if you increased the breaker in your load center(breaker box).Thanks everyone , that’s what I needed to know going to get a 30 amp put in at the house.
I had a 2008 5er with 30A service. I had an adapter to plug it in to a standard 15A outlet on the house.Thanks y’all will I be able to run the ac a short period?
…unless the breaker is badI had a 2008 5er with 30A service. I had an adapter to plug it in to a standard 15A outlet on the house.
I could run a few lights and the TV wihout any issues. I could run the A/C if I turned off the lights and TV to start the A/C. Once it fired up, I could turn the TV and a light or two back on.
I could NOT run the A/C and microwave.
If you overload the house 15A braker, it will pop. You will not start a fire unless you change the breaker to a 30A without changing the wire.
Your RV is safe, since anything over 15A is going to trip the house breaker.
