Rig: 2000 Itasca Suncruiser, 35', gas puller, owned 4 years
Came to check our Suncruiser in RV storage lot and found the exterior vent panel and frame behind the refrigerator on the ground. Previous owner used non-hardening caulk on the frame with the removable panel, then stuck it into the hole. Apparently, heat/sun/wind/rain finally got in between panel and exterior and it popped out. (Could have come off on the road!) I scraped the majority of caulk off both frame and hole edges, applied clear FlexSeal glue and pressed the panel/frame in. Used glue to hold panel frame in place instead of caulk previous owner used.
