- Nov 2, 2019
- Fulltiming
- London Aire 4551
- Yukon Denali
- Yes
As I hunker down in Kalispell, MT, the generator of my coach has come on twice in the last 2 days (I've been here 2 weeks.). When I look at my Control Panel, the voltage on L1 and L2 flucuates between 116 and 117, respectively. Even so I was able to cook, use my washer and dryer, run the a/c which I found weird. Newmar told me I need 118 volts minimum on each line to run my coach. Then today, the generator came on. L1 and L2 were both showing 117 volts. I only had the a/c on - no extraordinary draws on power. I shut everything down and then just turned on one a/c and the generator immediately kicked on again. I talked to the owner and his electrician. The electrician said that by law the power can fluctuate within a range of 10%, i.e., the voltage could be as low as 108 on a line. I told him that would not be enough power. This is a new campground so they are trying to figure things out. They may be a little underpowered, but it seems so strange when my generator comes on. It seems random. In any case, really nice people. They want to make everything right, as they intend to expand. Thank goodness for AGS to protect my monster dogs. Oops, I digress. So my questions are as follows:
1. When they checked my pedestal, L1 and L2 read 119. My Control Panel said 117. Right now, my Control Panel reads 116 and 117 on L1 and 2, respectively and I'm not having any issues. Is the Control Panel inaccurate? Is there something that would cause the difference in the readings? Is there something else I should check? Is it indicative of another issue I may be having?
2. What would I notice that would suggest my transfer switch is failing? And what do I need to do to make sure my transfer switch is okay? Is this something I need to check? Can I do it or do I need to call a mobile rv tech?
Any other feedback would be greatly appreciated.
Thanks as always for your help. ?
Renee
PS The readings on my Control Panel seem to be accurate for all the parks I've gone to previously.
Renee
