- Nov 2, 2019
- Fulltiming
- London Aire 4551
- Yukon Denali
- Yes
After sitting for a month in hot weather, I was worried about my DEF and turns out rightfully so. I started the big girl up the day before I was set to travel and the DEF gauge lit up like it was on fire. Got a check engine light with DEF Concentration High message. I aired up and shut the coach down and restarted it and the message went away. Meanwhile I put some fresh DEF in to hopefully make things mo betta. Travel day...I started the coach up and got the High Def Concentration Message again. Shut the coach down, banged on the sensor and started it up again and the message went away. I still have a yellow triangle with exclamation point with message Emissions, but that's it. Any thoughts?
I arrived at the campground yesterday and the Silverleaf thinks it is July 6th. Today it thinks it is July 5th. My radio doesn't know what time it is and the navigation system won't come on so I finally decided to do the firmware update on the radio. I put the thumb drive in over an hour ago and nothing appears to be happening. The following message has been on the screen. Has anyone else done the update? Thought I'd check here before I sit in a 45 min queue for customer service help.
Thanks for any help/thoughts/advice.
As always,
Renee
As always,
Renee
