Thanks, Neal for your reply. I am still a bit confused about my tankless water heater. I've seen some info that says you have to do something with the bypass valve, and other info that says "don't ever touch the bypass valve on a tankless water heater!". Do you know if i need to do anything at the tankless water heater when dewinterizing my unit? ThanksClean RV, inspect and clean, look for nests, critters, etc. then flush out the antifreeze. May want to sanitize the fresh tank, etc. change all filters related to water filtering (house, refrigerator, etc.).
I am good to go. Unit is dewinterized and i now understand bypass valves!!Thanks, Neal for your reply. I am still a bit confused about my tankless water heater. I've seen some info that says you have to do something with the bypass valve, and other info that says "don't ever touch the bypass valve on a tankless water heater!". Do you know if i need to do anything at the tankless water heater when dewinterizing my unit? Thanks
