jagpot
RVF VIP
- Nov 17, 2020
- California
- King Aire
- Spartan
- Cummins
- Jeep Wr Sahara
Thanks Neal. I know you use the Cacade. How often do you do that?Typically YES and I also typically travel with a full fresh tank BECAUSE getting to the next location is never a guarantee in these machines and I'm prepared to boondock at all times. So black/gray empty, fresh full, is my MO.
I watched a video from National Indoor Rv Center and she used the term "Flushing" the tanks. I think rinse would also be appropriate. She dumps the tanks,closes them fills the tanks again, hits the macerator and dumps again. Both Black and Gray. All this is done in the Wet bay by switches.First off, I don't know what you mean "flush" - I was referring to EMPTY. My coach has a black tank rinse system, I do it as often as I can but not always. As to the cascade or dawn tank treatment, I'd say monthly at most. I think routine tank dumping is cleaning sufficiently but I think adding a cleaning agent from time to time "may" help. No way to know.
The high end Newmars have a gray tank flush. The lower or mid range do not. I think it is only the Essex and KA, but might also be LA.I watched a video from National Indoor Rv Center and she used the term "Flushing" the tanks. I think rinse would also be appropriate. She dumps the tanks,closes them fills the tanks again, hits the macerator and dumps again. Both Black and Gray. All this is done in the Wet bay by switches.
Do you flush your tanks each time you unhook? Do you flush both black and gray? How often do you clean tanks with something like Dawn or Cascade?
