Front end shaking from 38 MPH to 42MPH
Notsotalltexan
San Antonio, TX
Tiffin
Allegro RED 340 38LL
Freightliner Custom Chassis
Cummins 340
2021 Jeep Wrangler Unlimited
Greetings-
We purchased a 2022 Allegro RED 340 38LL this summer. It now has 24,200 miles on the odometer. The original owner added Safe-T-Plus. When I first drove it it pulled to one side so I had that issue resolved by a big truck alignment shop in Nashville. Then I started noticing that when I hit 38 to 42 MPH, the front end shakes. Faster and slower than this window, no shaking front end. Two weeks ago I took it to a shop to have the front wheels balanced. This made absolutely no difference.
Is it possible the front tires are out of round? The tires are the original Michelin.
I'd like to know if this issue has happened to anyone here.
Thank you,
Laurent Perron
If it was out of alignment ,it wore the tires unevenly..Realigning and balancing wont correct the tire wear. I believe thats your issue , if theres no broken belt in a tire and no loose bearing or steering component
If it was out of alignment ,it wore the tires unevenly..Realigning and balancing wont correct the tire wear. I believe thats your issue , if theres no broken belt in a tire.
Thank you for your comment.
I just read some great posts from a thread called Front End Shaking. It sounds like one or both of my front Michelin tires are either mounted wrong or out of round.
If the tires are not steer tires, try rotating to rear. If that corrects the problem, you have a defective tire that balancing will never correct.
I had a similar issue with a previous motorhome; it was a bent, not out-of-round, wheel.
Did any shop do a runout? They can use a dial indicator to accurately measure the radial and lateral runout of your tires and determine if the issue is with the tire, the wheel, or another component.
We had a similar shaking, but on the rear. And it was the same problem - a bent wheel. We just lived with it and when we got new tires the balancing was done with “ground force” type load.
They showed me - without the load being placed on the tire during the spin everything looked fine. But once they put the load on the tire the wobble was visually obvious.
New wheel and now the annoying vibration at certain speeds is gone from the rear of the coach.
If it was a bent wheel, wouldn t the vibration continue above 42 mph? I m betting tire
Not Necessarily. The rim will flex causing a different weight distribution. At the same time, the tire has the same posablity. A defect in the casing can change balance due to deformity in the tire.
As I recall, my vibration was in the 55-60 mph range, and yes, it would stop once I drove faster.
So you are saying the steel wheel will straighten itself out after 42 mph ?
I'm not saying that at all. I said I had the problem, found a bent wheel, replaced it, and corrected the issue.
Our vibration with the bent wheel would change at different speeds. It didn’t go away 100% but did go away mostly at full highway speed where you could only feel it if you were lying on the bed above it.
Being a rear wheel it wasn’t felt in the steering.
Check the tire pressure, check the tires for unusual wear, have them put on a balancer and spun to check for bad tire or bent wheel, have a shop check wheel bearings. There is not enough miles on the vehicle to even consider worn front end parts..
Thank you for your input, Jim.
Hey Jim-- As soon as we return to San Antonio, I will take the RED to a shop on the PanAm Expy I've used before with great results called Southwest Brake and Alignment. I took both my 2012 Navion and 2016 Navion to them to true the out of round Continental Tires.
