Yes, it’s a Dometic. I’ve changed the sail switch. I’ve made sure the propane is good by lighting the stove top and water heater. It will come on, ignight for a few seconds then the burner will go out and the fan runs. It will oscillate like that until the room temperature is met.IF you have access and are comfortable doing so try cleaning the igniter and burner. Was the furnace functioning prior to this problem?
