Fuse box access on 2013 Chevy 2500 Roadtrek Ranger RT
Clyderigged
I believe the power window circuit breaker is kaput and I cannot get to it with the front "Captain" style seat in the way. Has anyone removed the seat to access the rear section of the fuse box and how is it done?
I had the same type of issue with my 2012, I had to rotate the seat just right and move the seat back to access the fuse box. I am sure you tried that already. Sometimes you can search on YouTube, Good luck!
Thank you for your reply. Yes I did that and to my dismay, the fuse I need is in the back corner. If the seat was not bolted on to a solid flat piece of steel, I might be able to gain access.
