RandyB
Retired
- Nov 15, 2019
- Portage, MI
- Ventana LE 4037
- 40' 11"
- 2021 Chevy Trailblazer
Earlier today, I posted this thread regarding some weird voltage readings
Fortunately, I was quickly helped and got out of the dilemma I thought I was in. I posed 3 questions. 2 were answered.
The 3rd question was asking about voltages at the transfer switch, which is connecting the power to run the coach systems. I’ve always read and have been told that RV AC systems are 2 hot legs of 120VAC. That voltage is between a hot leg to neutral or ground. Hot to hot should have 240 if it is split phase.
During testing, my measurements do not follow this guidance.
Hot red to neutral white = 120
Hot black to neutral white = 120
Hot black to hot red = 0
Ground to neutral = 0 with continuity
If the pedestal power is supposed to be 240 volts between the hot leads, why on generator is it not? Is the generator not split phase?
all systems are running properly.
Answered - Electrical Readings while on Generator
2017 Ventana LE 4037 Onan 8HDKAK-1046N MS2012 Inverter Precision Circuits Inc Central Monitor Panel No shore power. Generator running, and waiting for the 30 second delay before starting anything. I could here the "thump" of the relay pull in at 30 seconds, but it was not quite as loud as what...
rvforums.com
