Jim
- Dec 18, 2019
- North Carolina
- London Aire 4551
- Freightliner
- Cummins / I6 Diesel Pusher 600HP / 1,950 ft-lbs
- 2016 Jeep Rubicon
So some of you have heated floors in your motor homes? Here's how we do it at Deer Springs!
I have a 3,600 sq ft house in the mountains of North Carolina. It gets relatively cold here in the Winter. Some of you in the really cold areas might laugh at us but we do get to a -3* several times a year.
We have an outdoor wood furnace with a 380 gallon "water jacket" that surrounds the boiler. A wood fire then heats the water to 185* at which time it is pumped through the floors of the house, heating it to whatever temp we want. Just like any other heating system, this one has a thermostat that tells the pumps when to pump in some hot water and when to stop.
In the Winter, we usually keep the thermostat set at 71*-73*. The system is completely silent as it doesn't rely on an air handler to pump hot air throughout the house. And it's equally warm everywhere in the house.
Here are a couple of pictures of the system. It's a little larger than what Newmar uses, but the concepts are the same.
