Help interior lights stopped working
Ezar
I have a 1996 Shadow Cruiser Pop up TC and the interior lights stopped working.
They do not work in 12v or Shore Power mode - checked fuses and breakers. Installed a new fuses and cgfi switch. A/C, water pump, furnace, fridge and outlets are working fine. Just cannot get lights working. Could I have problems with convert or something else? Suggestions welcome.
Have you checked for rodent damage? If the converter was the probelm they would still work on battery, just not on shore power. Since its both, and not fuses or breakers, I’d look for wiring issues.
Found out I have a broken connector to the 15 amp blade fuse. Have not found a replacement connector and thinking about replacing converter with new technology. It is a 1996 Magnetek 6600 series any recommendations for replacement ?
Thanks for the reply
