Currently, I have two Poynting 2-in1 Cellular (2x2 mimo) and I'm running a Max Transit Duo with two sims active at all times.
In the coming months, I plan to overhaul my setup, and will likely go to:
Max BR2 Pro 5G with two active sims + Max BR1 Pro 5G with active sim in BR2 wan port (or some other setup with three 5G capable modems all active for bonding, redundancy, etc. - will soon be adding a t-mobile sim into my mix).
So, at minimum I need to add a third antenna, and more likely upgrade to 4x4 MIMO antennas? I'm assuming there are no combo antennas that would handle multiple radios at the same time?
Any advice from anyone that recently has gone down this route/researched current offerings would be greatly appreciated. Not looking for the cheapest, but instead the best.
I have zero ability to fabricate, 3D print, etc., so will be looking at fairly basic installs (currently flat on my roof, but tried to install them so would have both be blocked by same AC unit, for instance).
