jack grochowski
- Mar 11, 2021
I had a regular weight distribution hitch with two spring bars and one sway bar. It did not meet my needs as our travel trailers got longer and heavier. If you go that route make sure the spring bars are suited for your application. My spring bars may have been too weak for my last two travel trailers. I went with the 1st generation Hensley Arrow (Orange) hitch and used a nut driver to tighten the spring bars. I would do it again if I had to.
It may depend on your rig. What you are towing with and the weight/size of what you are pulling.
I am looking for opinions on Hensley hitches.
are they worth it?
are they easy to hook up/unhook?
thanks
I have never used weight distribution or anti sway personally but a good buddy and my cousin both use the Hensley and swear by them. Both have told me its the cats meow over other systems. Once you do it a few times its a simple process hooking up.I am looking for opinions on Hensley hitches.
are they worth it?
thanks
Your setup is mot much different than mine. I use Recurve 6 and it works great.7000 pounds, 30 feet long. 555-pound tongue weight according to the brochure
Ford Expedition Max. rated for 9000 pounds.
